I can only save a Parasolid-part-file or a Solid Works-part-file in Gomagic Design and then use it in Solid Works.
I can also save a Geomagic Design drawing to a dwg-file for using in Solid Works. Then i can choose a sketch from the drawing and rebuild the part again.
You should try with Solid Edge, noob.
