Need help with sweep cut
Hi I need help with sweep cutting knife blade. The problem is that i cant sweep from profile along spline to second profile. Sorry if the question is stupid but i am new to solidworks and i dont find something similar in internet.
http://i39.tinypic.com/2z5m7t4.png
Here is how I did it with SW 2012:
Answered with a tutorial: https://grabcad.com/tutorials/need-help-with-sweep-cut
I think a change of method.
I would use mirror at end - this will simplify the sweep cut.
The path for sweep need to change to get the curve at blunt end.
For your sweep - try to sketch the profile "normal" to the path, rather than at an angle.
Answered with a tutorial: https://grabcad.com/tutorials/need-help-with-sweep-cut--1
I would only use the right profile. Make a spline for your profile to follow by using the convert entities ( you may need to extend it past the tip of the blade). If you upload your current file I can play around with it and give you a tutorial.
Here the file. I tried only with the right part but its not proportional.
Sorry i have forgot for different versions. Here
It worked thank you,but can you tell me how to cut only in the red area http://i43.tinypic.com/t6flzs.png
