Non-linear material in SW Simulation
My friend you have hit pay dirt!!
I've been playing with this for the past year and have also started seeing a shrink!!
There are a few ways, but the most accurate is to create your own alloy/composite in the 'custom materials' module. As you know the Sim module requires various properties like stress, strain, yield, E~~modulus, at certain temperatures. It's pretty painful! But the best way to learn - at least for me - was to look at the properties of something like 6060aluminium that's already in the library. Then at ?? 20degC draw a 5 meter beam supported either end and put somthing heavy on it, not in the middle for fun, and watch it bend. Then do it again 85% of melting temp for that alloy. This way you get an idea of how SW interprets the variables.
I hope this helps. What is it you are running a sim on?
Best Regards,
James
