Problem in using a Mating Assembly Macro
Hi all
I was using this post :
http://www.eng-tips.com/viewthread.cfm?qid=175155
to do some matings in Assembley , but whether I open a part or assembly I get a run time error 91 : Object variable or with block variable not set
I don't know in which line the set is not compatible with my assy, but I have chosen one of the components first ,only that I opened as Assembly that the parts already have a mating
is this a problem ?
