Problems with loft option in Autodesk Inventor
When I am trying to create a loft using two profile and two curves it sends me a message that says that a curve is not intersecting a profile. I dont understand it I drew all of it correct If anyone has any exp with this please reply.
Here this is the file but I do not know how to fix the loft problem if anyone can do it and send me the completed lofted crane hook I will be more then thankful to him.
There where problems with intersections. Here is Quick and dirty fix. I suggest that You draw both rails (sketch1 and 11) again with splines to be sure that Your Coincident Constraint work precise.
As Leo wrote, there is a problem with intersections. I think that you should try to redesign sketches: first you need to sketch sections of the hook and then do "Project Geometry" and connect all drawn sections with the rails of the hook.
Please also check this link out, I believe that this might be helpful:
http://au.autodesk.com/au-online/classes-on-demand/class-catalog/2013/product-design-suite/ma3068
