revit importing probleme
when i try to import dwg file to a revit project or a revit family these message appear:"Some ACIS objects could not be imported. To import them, use AutoCAD to convert them into polymesh objects and reimport."
first if u will be import a 3ds max soft ware, then export a *.rvt file formate that problem is DONE....
