Hello.
I need some help with surface to solid. I made a surface for a lamp reflector, but cannot add body or create thickness etc.
I dont use surfaces in my daily work, therefore could use some assistance with the part.
Done in Ordered.
If you help, will share base files and assembly.
You simply need to use "Add thickness" feature.
Accordingly to the geometry the maximum thickness I am able to add is 7 mm
see the attached file.
