surface to solid problem
hi
i had a .stl file. i use curve wizard to find curves.
after that i found the curves in 3d sketch, i used surface loft.
now i have a surface loft.
how can i have a solid part?thank u
Hello Sir,
I'll try to help you, just follow the tutorial in pictures bellow, and check the SolidWorks and IGES fies.
Best Regads,
Ridwan S
Answered with a tutorial: https://grabcad.com/tutorials/surface-to-solid-problem
