Tutorial: How to manage STL files in CATIA
- Usually STL files generated by easy-use / low-cost CAD software have poor quality
- I found a lot of STL files on the internet and when I tried to open them they were totally distorted
Generating STL files with CATIA usually will result in having a good quality of the STL file, but for a optimal and personalized quality of the STL you will have to do it manually -> this process is described in the following slides
I've added a tutorial describing how to generate more accurate STL files using CATIA software. I hope it will come in good use for some of you.
Hi friend, thanks so much for your time, and for this tutorial!!! its sounds somehting new for me.
Have a good day,
Best Regards,
