Using 3D sketch to create new part in assembly (SW2016)
Hi everyone,
I'm modeling a tubular frame of three-wheeled vechicle. I have a welded prototype and I've already measured and put all important points in the model and now I would like to add new part to the model which are bent tubes which will fit the rest of parts.
I wanted to use 3D sketch and welded construction module, but is it possible to add a new part directly in assembly using 3D sketch?
When I'm trying to do so the 3D sketch icon is inactive, and I have to chose the plane to start normal 2D sketch.
I've used welded construction module before, but never directly in assembly.
I would be grateful for any advice.
Thank you.
