Altium Design. Tutorial 14: How to add Parameters to Multiple Components in AD21 Integrated Library.
#Adding #Parameters to #Multiple #Components in #altiumdesigner #integrated #library
#Parameter #table #editor #altiumdesigner designer
#components #parameters
Adding Parameters to Multiple Components in integrated Library Altium Designer
Parameters are a key element of each component, and it is common for many of the parameters to be used across multiple components. As well as adding them individually to each component, you can also use the Parameter Manager command (Tools » Parameter Manager) to add them to multiple components. As well as adding or removing parameters, the values of parameters can also be edited across multiple components.
Notes about editing multiple parameters:
1. Parameters can be edited across the components in a library or across components used in a schematic design using the same process. Select Tools » Parameter Manager in either the schematic or schematic library editor to start the process.
2. Because parameters can be added to a variety of different objects, the first step is to select in which object types the parameters are to be edited in the Parameter Editor Options dialog.
3. Parameter editing is performed in the Parameter Table Editor dialog. The dialog can be accessed in different ways, so the dialog caption can change. The way you work in the dialog is the same regardless of how it was accessed: use the standard Windows selection keystrokes to select the cells of interest then right-click and choose an edit action.
4. Changes are not performed immediately; they are done via an Engineering Change Order (ECO).
5. Each cell that is being changed is marked by a small colored icon. Refer to the Parameter Table Editor dialog page for a description of each icon.
#Altium #PCBdesign
