Convert Mesh to Body Solidworks - Mesh Modeling - Change from STL to Editable Solid
SEE VIDEO BELOW
DO NOT CLICK HERE: http://bit.ly/projetos_infinity
How to Convert Mesh to Body in Solidworks - Solidworks Mesh Modeling
That's what you'll learn in this tutorial.
I will teach you two methods, where in the first one you will open the stl file normally and only then convert the mesh (graphic) into solid body.
And in the second method you will directly open the stl file in solid body. So watch the entire video to see which method best fits your
necessity.
To start the conversion, we must right-click on the tools tab, and enable the mesh modeling tab.
Afterwards, with the mesh modeling tab enabled, we must click on convert to mesh body, and then click on the mesh that we want to convert, and then click on ok.
There, your mesh turned into a solid body.
And now it has mass and volume.
In the second method to open straight as solid body and we don't need to convert. Just click on options, then select solid body, and click ok.
Now just click on open and the file will automatically open as a solid body.
Just click on file type, and choose the mesh files option, which will have the stl file extension.
Then just click on the file, and then click on options.
Thus, making it an editable body, that is, an editable stl file, as you can see, it is possible to perform extrusions normally
