Creating a PCB with Fusion360
See how to create an electronic PCB with particular shape with fusion360
Step 1: Creating the shape
- Launch a fusion 360 instance and create a sketch.
- Then draw the shape you need ! (in the example this is a polyline)
Step 2: Creating the PCB
- Once your sketch is saved, go to the "SOLID" part and choose :
"Create independent PCB"
- Once you've been click on it, select your shape.
Step 3: Configuring PCB
- Choose the right option for your PCB
And DONE !!! that's all you need to create a PCB from a particular shape .
