How to add knurls in bottle caps (keyshot)
Learn how to quickly add knurls or "grip ridges" on any surface
Step 1: Add mesh node
Since my model is a cylinder, I changed the mapping type to cylinder.
Edit shape to "line",
Edit "shape width" to create thinner lines or thicker ones.
Change the scale and pattern spacing as you wish.
Step 2: Connect to Displace
Connect mesh to Displace and Displace to Geometry
Edit displacement height, I used 0.1 mm.
If you want more clean lines, lower the triangle size to 0.05 or any number below 1.
After editing, click on Execute Geometry Node.
Step 3: Results
