How to create a rope drive?
Small
Here is my solution. In this the rope is just a part which don't work as in Assembly or we can say that for representation only.
    Start SolidWorks in Part mode.
    Right plane >> Sketch.
    Draw this sketch.
    Revolve it. Save this part.
  5. Step 5:
    New part. Front plane >> Sketch.
  6. Step 6:
    Draw a rectangle.
  7. Step 7:
    Extrude it.
  8. Step 8:
    Front face >> Sketch.
  9. Step 9:
    Draw three circles.
  10. Step 10:
    Extrude them.
  11. Step 11:
    Save this part.
  12. Step 12:
    Start a new assembly and insert this part.
  13. Step 13:
    Insert three part1.
  14. Step 14:
    Mate. Select this face of the pulley.
  15. Step 15:
    And this face of the part.
  16. Step 16:
    Generate coincident mate.
  17. Step 17:
    Select inner face of the pulley.
  18. Step 18:
    And the circular face.
  19. Step 19:
    Generate mate.
  20. Step 20:
    Generate similar mates for other parts.
  21. Step 21:
    Assembly features >> Belt/Chain
  22. Step 22:
    Select this face.
  23. Step 23:
    And this face.
  24. Step 24:
    And third face.
  25. Step 25:
    Enable Create belt part and click OK.
  26. Step 26:
    Click OK and save the assembly file.
  27. Step 27:
    Now the belt part is generated.
  28. Step 28:
    Open the belt part.
  29. Step 29:
    Reference Geometry >> Plane.
  30. Step 30:
    Select the line and the end point. Click OK.
  31. Step 31:
    Plane1 >> Sketch.
  32. Step 32:
    Draw two center lines.
  33. Step 33:
    Draw 4 equal circles tangent to them in each quadrant.
  34. Step 34:
    Trim the inner lines.
  35. Step 35:
    Exit the sketch. Swept boss/base tool.
  36. Step 36:
    Select the circle sketch as profile and the belt sketch as path.
  37. Step 37:
    Under orientation select twist along path.
  38. Step 38:
    Input no. of turns.
  39. Step 39:
    Click OK.
  40. Step 40:
    Window >> Assembly.
  41. Step 41:
    And we have rope drive.
Please log in to add comments
