How to draw Hexagonal Nut In NX Unigraphics?
Missing small
In this tutorial I will show, how to draw a simple hexagonal nut in NX Unigraphics.
    Start your NX xx version you have!
    1.Then click on New file.
    2.click on Model
    3.click on sketch
    4.select plane
    5.draw a hexagon of appropriate size
    6.finish sketch and extrude it
    7.click on hole command
    8.select point at which hole should be
    9.do the hole
    10.Click on thread command
    11.select hole face and give thread dimension
    12.You can chamfer edges by revolving triangle sketch
Please log in to add comments
