Problem with extruding 2D Shape in Inventor
Small
ok
    right click on sketch > edit sketch
    you will notice that you can move the lines apart (no constraints) so click on them and move them apart a little bit to able to choose the end points.
    activate the coincident constraint commend
    click on end points to join them.
  5. Step 5:
    your final result should be fully constrained, if you try to move any line the whole tingle will be moved.
  6. Step 6:
    Ready to extrude!
Please log in to add comments
  • Missing feed
    Ahmad Mehmood
    Hey mine is closed and constrained. There are apparently a gazillion reasons for this problem. Sometimes the loop intersects other loops. Is it possible that i upload/share/send my file and some angelic soul may tell me why can't i extrude ?
    I would be soo grateful.
    March 1st, 2018 03:36
