Solving Label Issue in KeyShot
This is a very common occurrence in KeyShot. You place a label in cylindrical projection, and the label is not only seen on the outside of the object, but also on the inside of the object, and this is not what we want.
We don't know if this has been fixed in the most recent versions of KS, but if it happens to you, here is a fairly simple solution.
Step 1: The Problem...
And the solution (One of them, at least in SolidWorks)..
