How To Move Multiple labels Fast In Keyshot
The "Map 2D" node inside the Material Graph will help you move multiple labels or textures simultaneously.
Step 1: Add "Model 2D" node
After adding your labels, open the Material Graph
Inside the Material Graph, Right click, go to Utilities, and select "Mapping 2D"
Step 2: Connect "Mapping 2D"
Connect the "Mapping 2D" node to every label we want to move simultaneously.
Step 3: Change Label Mapping Type
Select your labels and change their Mapping type to "Node"
Step 4: Ready to Move Simultaneously
When labels are connected to the "Mapping 2D" node and their Mapping type is set to "Node", you can freely move around labels simultaneously.
Be sure the "Mapping 2D" node is selected to move, rotate, or scale all labels at once.
