Tutorial - Analysis of Bracket in ANSYS Workbench?
Here is the tutorial.
Start ANSYS Workbench.
Double click Static Structural.
Input Name Bracket.
Right click Geometry >> Import geometry >> Browse.
Select the bracket.igs file.
Right click Model and select update.
The model is updated and it's OK.
Double click Setup.
The Mechanical windows shows up.
Click Loads >> force.
Step 11:
Input Magnitude = -1000.
Step 12:
Select the surface and then click apply for geometry.
Step 13:
Define the direction to downward.
Step 14:
Now click Supports >> Fixed Support.
Step 15:
Hold down CTRL key and select the hole surface. Click apply in details.
Step 16:
Now we have to define which results we want. Right click Solution >> Insert >> Stress >> von-Mises.
Step 17:
Add Deformation >> Total also.
Step 18:
Click Solve to start solution.
Step 19:
After the solution is completed we have tick marks in Solution.
Step 20:
Select Equivalent Stress to view the plot.
Step 21:
Select Total Deformation for deformation plot.
