Tutorial - Analysis of Bracket in Mechanica?
Small
Here is the tutorial.
    Applications >> Mechanica.
    Click OK.
    Properties >> Materials.
    Select steel.mtl and click >>>.
  5. Step 5:
    Now steel is added to materials in model.
  6. Step 6:
    Now we have to assign the material to the model. Since we have one part therefore only one material can be assigned. Properties >> Material Assignment.
  7. Step 7:
    Select the part and click OK.
  8. Step 8:
    Now a yellow symbol will appear which will indicate that the material is assigned.
  9. Step 9:
    Insert >> Displacement Constraint.
  10. Step 10:
    Select all holes while holding down CTRL key and click OK.
  11. Step 11:
    Now all the holes are fixed.
  12. Step 12:
    Click Insert >> Force/Moment load to apply load.
  13. Step 13:
    Select the top surface of the bracket and in Z direction input 1000N which ~101Kilograms. Click OK.
  14. Step 14:
    Now the force is applied and shown in Yellow colour.
  15. Step 15:
    Click Analysis >> Mechanica Analyses/Studies.
  16. Step 16:
    Click File >> New static.
  17. Step 17:
    Input name Bracket and click OK.
  18. Step 18:
    Click Start run.
  19. Step 19:
    Click Yes.
  20. Step 20:
    Now the study is completed. Click Close.
  21. Step 21:
    Click Analysis >> Results.
  22. Step 22:
    Click Insert a new definition icon.
  23. Step 23:
    Select bracket and click Open.
  24. Step 24:
    Keep the default settings and click OK and show.
  25. Step 25:
    Now the Stress plot is shown.
  26. Step 26:
    Click Insert >> Result window.
  27. Step 27:
    Select Bracket and click open.
  28. Step 28:
    Change stress to displacement.
  29. Step 29:
    Goto display options tab.
  30. Step 30:
    Check deformed, show loads & show constraints. Click OK and show.
  31. Step 31:
    Now we have the displacement plot in the same window.
  32. Step 32:
  33. Step 33:
    Select bracket file and click open.
  34. Step 34:
    Change stress to strain.
  35. Step 35:
    Under display option tab check deformed and click OK and show.
  36. Step 36:
    The strain plot is also added to same window.
  37. Step 37:
    We have successfully completed the studies of Bracket in Creo Elements/Pro aka Pro/Engineer Wildfire.
Please log in to add comments
