Tutorial for beginners: how to make brass knuckles in Solidworks?
STL part file and renderings can be accessed here Brass knuckles
    Download this image.
    Open solidworks, choose part and click OK:
    Click on Sketch and choose any plane to sketch on.
    Choose Sketch Picture and open the picture you downloaded.
  5. Step 5:
    Carefully using Sketch tools follow the contours (there is Autotrace add-in in Solidworks, but i would not recommend using it for better end result)
  6. Step 6:
    In the Features tab, click on Extruded Boss/Base.
  7. Step 7:
    Choose the thickness you prefer. 30 to 40 mm seems okay. Click on the green tick.
  8. Step 8:
    To make our part more appealing we are going to add fillets.
  9. Step 9:
    Click on the left button and drag the mouse over the part to select all the edges. Choose the radius you like. In my case, i chose 3mm. Click the green tick and you are done!
  10. Step 10:
    Done.
  11. Step 11:
    Do not forget to hit "It worked" if you liked the tutorial.
