Tutorial: How to create Rims from Cans with Creo Parametric
Do you like a Wheels? ... I like it too .... here is short Tutorial: How you can use your models for miscellaneous design :)
Create or Download Can (Tin) - the GRABCAD library is full of nice models ;)
Create copy of Can and deform it - you can use Warp feature for this deformation
Create base wheel ring (you can use Revolve feature)
Create assembly from created parts
Render your design with rendering software - for example PTC Creo Parametric ARX
