Tutorial how to make engine part 11
Small
Cylinders - 2
    open a sketch on front plane and draw water canal profile
    extrude it
    create a plane bottom of body and use mirror command for to mirror water canal
    after open a sketch on this surface
  5. Step 5:
    draw a sketch like this and use cut extrude command
  6. Step 6:
    go to left side, open a sketch and draw a sketch like this
  7. Step 7:
    extrude it. please attention that to make direction 'up to surface'. select the outer surface of the cylinder
  8. Step 8:
    open a sketch on same surface and draw semi-circular profile. it have to be closed profile
  9. Step 9:
    create the plane 3 ( it is at the center of water canal) then draw the path.( we will use sweep command)
  10. Step 10:
    use sweep command. then mirror it
  11. Step 11:
    create a inlet part like this
  12. Step 12:
    close the back side with your method
  13. Step 13:
    mirror all things and your water cooled 12 cylinders are ready
Please log in to add comments
