Tutorial: How to use rib feature in Autodesk Inventor?-Lesson 2
Tutorial by Abhijeet
Small
Tutorial to use rib feature in Autodesk Inventor?-Lesson 2
    Sketch an L shape and exit the sketch mode.
    Click on extrude command.
    Extrude the profile to a certain limit according to your requirement.
    Plane-> midplane between two parallel planes.
  5. Step 5:
    Select the two side planes to create a plane in the middle.
  6. Step 6:
    Invoke a new sketch on the plane.
  7. Step 7:
    sketch a line to perform the rib. Exit the sketch.
  8. Step 8:
    Click on rib.
  9. Step 9:
    Choose "parallel to sketch plane" option in the rib dilog box. Provide some thickness. Select the side to provide thickness or select axisymmetry.
  10. Step 10:
    Select "finite" to get a rib as shown in the figure.
Please log in to add comments
