Tutorial: how to use the file format. jpg eg for format CAD in the T-FLEX Parametric CAD?
Small
You can do it on any wall model
or the active surfaces
    1) insert the image. Jpg to the active work plane
    (wall / surface work / surface of a cylinder or sphere)
    Now the best in the filter selection
    deactivate the filter "images" and set this image level -1 in the properties
    2) turn on the option sketchbook
      and using a variety of available options (lines, rays, splain) we outline the necessary fields
    3) we are ready 3D profile
    -select it and copy (right mouse button)
    4) paste in our file (right-click) in the model window
    use the option "transformation" to set our profile
    against the wall important to us
    use the scaled to the required size
  5. Step 5:
    5) of the "wall"
    Select "imprinting" (throw, projection)
    acceptance when ready
    It is 3D ready profill
    on the wall where you need it
    to create a 3D geometry
    Next photos show different results
    on different walls
  6. Step 6:
    6)
  7. Step 7:
    7)
  8. Step 8:
    8)
  9. Step 9:
    9)
    thank you
