Tutorial - Modeling a PAN Head with taper neck Rivet?
Here is the tutorial.
Top plane>>Sketch.
Draw a circle of 16mm dia.
Reference geometry>>plane.
Offset top plane at 7mm.
Plane1>>sketch.
Draw a circle of 10mm dia.
Select lofted boss.
Select both sketch and adjust the connectors.
Select the bottom face and then plane.
Offset at 5mm.
Step 11:
Plane2>>sketch.
Step 12:
Convert the upper edge.
Step 13:
Extrude it with draft enabled at 15º outwards.
Step 14:
Plane2>>sketch.
Step 15:
Convert the edge.
Step 16:
Extrude it by 20mm.
Step 17:
And we have the part.
