Tutorial - Modeling a Cup headed sq. neck bolt in SolidWorks?
Here is the tutorial.
Start SolidWorks in Part mode.
Top plane>>Sketch.
Draw a circle of 22mm dia.
Extrude it by 1.25mm.
Top face>>Sketch.
Draw a polygon circumscribed in a circle of 10mm dia.
Extrude it by 7.5mm.
Top face>>Sketch.
Draw a circle of 10mm dia tangent to the sides of the polygon.
Extruded cut. Draft enabled at 60º.
Step 11:
Top face>>Sketch.
Step 12:
Draw a circle of 10mm dia.
Step 13:
Extrude it by 50mm.
Step 14:
Front Plane>>Sketch.
Step 15:
Use arc tool and make this profile.
Step 16:
Draw a line at the center and trim it. Now close the profile.
Step 17:
Revolve it.
Step 18:
We have the part.
Step 19:
After cutting threads.
