Tutorial - Modeling Bolt in Creo Elements aka Pro/E?
Small
Here is the tutorial.
    Sketch >> Top plane.
    Click Pallete tool.
    Choose Hexagon.
    Drag it to workspace and adjust it to origin.
  5. Step 5:
    Delete the dimension of the side and dimension the circle.
  6. Step 6:
    Extrude it.
  7. Step 7:
  8. Step 8:
    Draw a circle.
  9. Step 9:
    Extrude it.
  10. Step 10:
    Edge chamfer tool.
  11. Step 11:
    Chamfer the circular edge.
  12. Step 12:
    Insert >> Helical sweep >> Cut.
  13. Step 13:
    Now press middle click OK.
  14. Step 14:
    When we have to select plane, select Front plane.
  15. Step 15:
    Draw a center line along the vertical axis.
  16. Step 16:
    Draw a line.
  17. Step 17:
    Exit the sketch and input the pitch value.
  18. Step 18:
    Draw a triangular profile.
  19. Step 19:
    Exit the sketch and direction be inside the profile.
  20. Step 20:
    Click OK and the feature is generated.
  21. Step 21:
    Sketch >> End face of the cut.
  22. Step 22:
    Convert the two edges.
  23. Step 23:
    Make another line about those lines.
  24. Step 24:
    Extrude it with remove material and click OK.
  25. Step 25:
    We have the bolt generated.
Please log in to add comments
