Tutorial - Modeling Nut in Creo Element aka Pro/E?
Here is the tutorial.
Sketch >> Top plane.
Draw a polygon with circle of 17mm dia and a circle of 20mm dia.
Extrude it by 10mm.
Sketch >> Right plane.
While taking the edges as the references Draw a Triangle with angle of 30º.
Revolve it about the center axis with remove material.
For other side repeat the same operation.
Insert >> Helical Sweep >> Cut.
Click Done.
Select Right plane.
Step 11:
Click Okay and then default.
Step 12:
Now we have to define the sweep profile i.e. the profile along which the helix will be generated.
Step 13:
Draw a center line about the horizontal axis.
Step 14:
Draw this line at 9.5mm to horizontal axis.
Step 15:
Exit the sketch and input pitch value = 2.5mm. Click OK.
Step 16:
Now draw the Cutting profile. This be Iso triangle.
Step 17:
Exit the sketch and the material direction be inside.
Step 18:
Click OK. Now we have the nut generated.
Step 19:
If you want to add a chamfer to the edge after helical cut operation, drag the insert here above the cut id.
Step 20:
Now create the chamfer on the edges.
Step 21:
Drag the insert here back to below the cut id.
Step 22:
We have the nut generated.
