Tutorial - Modeling Drill bit in Creo Elements Pro aka Pro/Engineer Wildfire?
![](https://d2t1xqejof9utc.cloudfront.net/members/avatars/29274/feed.jpg?1552114776)
Here is the tutorial.
Sketch >> Top plane.
Draw this profile.
Revolve it about base line.
Again Sketch >> Top plane.
Draw a line and spline tangent to it.
Exit the sketch and go to Insert >> Sweep >> Cut.
Press CTRL and then select both line and spline and press middle mouse button.
For section draw a circle with center outside the drill body.
Material side be inside the circle.
Click OK and the feature is generated.
Step 11:
Select cut feature and then Edit >> Pattern.
Step 12:
About X-Axis at 360º two times. Click OK.
Step 13:
Now we have two cut feature generated.
Step 14:
Insert >> Warp.
Step 15:
Select the body and then twist tool. Under References change direction to Right plane.
Step 16:
Input the angle value 180º and click OK.
Step 17:
We have drill bit generated.
