Tutorial - Modeling Lamp shade in SolidWorks method 2?
Here is the tutorial.
Top plane >> Sketch.
Draw a polygon circumscribed in a circle of 100mm dia.
Exit the sketch. Reference geometry >> Plane.
Offset the top plane by 80mm.
Plane1 >> Sketch.
Draw a circle of 50mm diameter.
Exit the sketch. Select lofted surface tool under surfaces tab.
Select both sketches as profiles and adjust the connector so as to perform a twist.
Filled surface.
Select all edges and click OK.
Step 11:
Front plane >> Sketch.
Step 12:
Draw a spline.
Step 13:
Trim surface tool under surfaces tab.
Step 14:
Trim the surface using spline as the trimming tool.
Step 15:
Thicken the surface with inside direction.
Step 16:
Thicken the filled surface inside direction.
Step 17:
Perform a cut on the top surface. And we have the part generated.
