Tutorial - Modeling Unified screw threads on bolt in SolidWorks?
Tutorial by Sudhir Gill
Small
Here is the tutorial.
    Start SolidWorks in part mode.
    Top plane>>Sketch.
    Draw a circle of 20mm dia.
    Extrude it by 50mm.
  5. Step 5:
    Top face>>Sketch.
  6. Step 6:
    Draw a polygon inside a circle of 32.5mm dia.
  7. Step 7:
    Extrude it by 10mm.
  8. Step 8:
    Top face>>sketch.
  9. Step 9:
    Draw a circle tangent to sides of polygon.
  10. Step 10:
    Extruded cut.
  11. Step 11:
    Check flip side to cut. Draft enable at 45.00º.
  12. Step 12:
    Chamfer.
  13. Step 13:
    At distance of 3mm & angle 45º.
  14. Step 14:
    Top plane>>sketch.
  15. Step 15:
    Select the outer edge and then convert entities.
  16. Step 16:
    Curves>>Helix and spiral.
  17. Step 17:
    Defined by Pitch and revolution. Pitch=3mm and revolution = 15.
  18. Step 18:
    Right plane>>sketch.
  19. Step 19:
    Draw a profile like this. Since pitch is 3mm so keep the length be little less than pitch since at 3mm it will have intersection error.
  20. Step 20:
    Sweep cut.
  21. Step 21:
    Select the profile and the helix as the path.
  22. Step 22:
    And we have the unified screw threads.
Please log in to add comments
