Tutorial - Simulation of Plummer block under torque?
![](https://d2t1xqejof9utc.cloudfront.net/members/avatars/29274/feed.jpg?1552114776)
Here is the tutorial.
Start SolidWorks and open the attached model.
Under simulation tab choose study advisor>>new study.
Let's keep the settings to default and select type Statis and click OK.
Under fixture advisor select fixed geometry.
Select the inner faces of the body of casting where the bolts will make it fixed.
Now we can see the green arrows. These arrows indicate that the body is fixed here.
Under refernce geometry select axis.
Select the circular face and click OK.
Under External loads select Torque.
Select the inner face and axis1 as the direction.
Step 11:
Enter the torque value of 100 & click OK.
Step 12:
Now click Run.
Step 13:
Now we have the analysis result of the plummer block under torque.
