Which is the best way to move a part along the X Y Z axis by a specified dimension?
Translate command is good for this. But if you dont like it, you will use "Axis System" command.
Here is the tutorial.
    Create point.
    Use Axis system command and select point as an origin.
    Use plane of axis system as a sketch plane.
    Create solid part.
  5. Step 5:
    To move part, just change values of point.
Please log in to add comments
