Help with error message
I changed the filament spool from abs to pla using genuine stratasys material. Now every time I try to print is gives an error message invalid material for part. I changed heads and installed cooling head. Can you give me a heads up on what to do next?
Where are you seeing/getting the error?
What program(s) are you using?
What 3D printer is it?
Have you tried to apply a different material to the parts while setting up the platform?
There is more than one problem so I will try to cover all of them. I am using a Statasys f170 printer. I was printing with ABS. I then unloaded the ABS and QSR from the bins according to directions. I then changed out the two heads and replaced with PLA head and cooling head. I opened a new roll of Stratasys PLA and loaded according to directions. Now when I try to print any type of model, I get three messages. Invalid material, Invalid material for build and Invalid material for printing.The PLA is the only material I have. I am out of all other material.
Got all of original problems fixed. Now when I try to print I get an error message that says "Model head extrusion rate warning" "Clear error and resume build". On GRABCAD print, at the bottom of the screen in a small dialog box it says f170 D01234 Out of Material. Can't be out of material because I just loaded a new spool of material.
