How to measure my part which is in stl file format?
I want to make an exact 3D CAD model of a fan:
http://www.nmbtc.com/fans/part-numbers/search/2004KL-04W-B50/5019.
I have two 3D scans (front and back) of my fan blades and I can not import the stl files into SolidWorks as a solid body because they are too large.
All I need is to measure the blades (actually one of them, because they are the same) to get the data I need to make a 3D CAD. I tried the way described here http://www.swtuts.com/?p=427 but it didn't work for me.
Can you please help me to get the desired dimensions?
Thank you very much!
Ok the tutorial didn't follow...
I'll retry :
Answered with a tutorial: https://grabcad.com/tutorials/how-to-measure-my-part-which-is-in-stl-file-format--2
I can carry them out successly . You can use Geomagic studio. Which can measure the blade. you want.
The best software for all 3d files is Netfabb.It is a open source software.
It can be downloaded from
http://www.netfabb.com/
Attached Screen shot of your file.
Select the measure from evaluate tab.
