How to scale assembly dimensions?
Does anyone know of a utility, macro or feature for Solidworks that will enable me to rescale my assembly dimensions on demand? I built an assembly and someone is willing to print it in 3D, but the whole assembly needs to be scaled down to 1/4 of the actual size, in order to fit the machine as a print out.
Save as part
Use the 'Scale' command.
Scale in modeller is not the right command. It will change the original dimension.
File > make drg from assembly >select sheet size > Insert view in sheet > Select frame > Scale > use custom scale
Also see sheet > (right click) > properties > scale
