option for curve driven pattern like solidwork.in Unigraphics
Pattern Geometry
Selected object to pattern.
2.Path Method = Offset, Select Path = spline
Path Method determines the relationship between the reference points of the pattern and the specified path.
For more information, click the Path methods for the Along layout link in Look up more details.
3.Count and Span spacing, Count = 5, %Span By = 100
Sets the type of pattern spacing. In this example, five instances will span a specified percentage of the first path.
4.Use Direction 2 , Direction by = Curve, Count and Pitch spacing, Count = 4
Sets the second direction. You can set the direction using either a curve or a vector.
If you select Vector, the Specify Vector options become available.
5.Location = %Arc Length, %Pitch By = 33
Sets the location of the instances based on percentage of arc length.
The location of each instance on the specified arc length is determined by the specified pitch percentage.
