Problem Copying Objects in AutoCAD ?
I am trying to copy a piping layout, along with structural, in same the drawing outside the drawing space, or anywhere.
Only the structural part copied. This layout was copied from a model drawing before, in to this drawing.
Using AutoCAD lite 2011, can you help?
2 Answer
You will not be able to copy ACAD_Proxy objects created in software that ACAD LT doesn't support.
Ok thanks.
