copy paste problem
I want to copy a sketch to another plane and the problem is that the paste ( ctrl v ) doesn't works .
in fact I exit the sketch and select the sketch that I want copy form design tree and from the toolbar menu
( edit - copy ) I copied the sketch then I select a plan and click on sketch and when I enter a sketch from the toolbar menu above ( edit-- paste ) I try to paste it but in the toolbar menu the bottom past ( ctrl V) is inactive.
so I can't paste the sketch that I have copied befor ...
