what is parametric modelling?
Parametric modelling means a model built where the features are dependent on the dimensions that constrain/define their form. This means that the model will update when you change the dimensions (either in the model itself or from the sketch that was produced from it - this sketch displaying the model's dimensions). It also means this model has a history defining the building sequence. Editing this sequence will also have an effect on the outcome...
