Why does the dimension change when i save a design in .stl format?
Hi, I use SolidEdge ST6 for designing. When i create a part in solidedge (say a cube) of 30mm dimensions, after saving it in stl format the dimensions in the stl file changes to about 2mm. This is totally wierd. I use netfabb to check my .stl files. Any help would be appreciated. Thank you.
