can any1 tell me how to measure weight of part in catia using "MEASURE INERTIA" command?
Small
If it is necessary first add a material to the part/assembly body and then right click on the specification tree that is on the part/product after that select propeties option.it will shows a dailog box in that go to mechanical option in assembly design you will find the mass,surface area,center of gravity,moment of interia.simlarly do the same procedure of other propeties
    Right-click PART1 in the specification tree and select Properties... from the contextual menu SELECT the Properties dialog box appears.
    Select the Mechanical tab.
Please log in to add comments
