Tutorial - Analysis of Circular beam under UDL in SolidWorks?
Small
Here is the tutorial.
    Right plane >> Sketch.
    Draw a circle of 50mm diameter.
    Extrude it by 500mm.
    Right click Material and select alloy steel.
  5. Step 5:
    Now go to Simulation tab and select New study under study advisor.
  6. Step 6:
    Keep the default settings and click OK.
  7. Step 7:
    Click Fixture advisor and Select fixed geometry.
  8. Step 8:
    Select the right back face as the fixed face.
  9. Step 9:
    Make the Top plane visible.
  10. Step 10:
    Select Force under External Loads Advisor.
  11. Step 11:
    Select the face and the top plane as the selected direction. Under force tab enable Z and input a value of 10000N with reverse direction.
  12. Step 12:
    Now our model is prepared for analysis.
  13. Step 13:
    Click Run to start the solver.
  14. Step 14:
    Now we have the stress distribution and the whole study analysis.
  15. Step 15:
    For displacement distribution click Displacement1.
Please log in to add comments
