Tutorial: How to make Dodechahedron
here is the simple tutorial.
just follow the images as instructions given in it.
This a render image which have to be made.
First draw sketch in top view as show in image
Use planer surface command to fill a single base of pentagon.
Do the same for four surfaces.
The angle used is calculated with long calculations. use the same value so that no gap formed.
Do as directed.
Do as directed.
Do as directed.
Do as directed.
Do as directed.
Step 11:
Do as directed.
Step 12:
Do as directed.
Step 13:
Do as directed.
Step 14:
This is final model.
