Tutorial how to make engine part 10
more detailed tutorial
    open a sketch on the right plane
    draw a centerline
    use features--referance geometry--plane command
    select the line and the right plane
  5. Step 5:
    then enter shown value
  6. Step 6:
    open a sketch on the plane that we created just now
  7. Step 7:
    draw a circle
  8. Step 8:
    draw two more circles
  9. Step 9:
    draw one more circle
  10. Step 10:
    draw a circle like shown
  11. Step 11:
    draw a circle again. it should be concentric with the circle that we created just now
  12. Step 12:
    now we will use trim command. sketch--trim command
  13. Step 13:
    before trim this lines
  14. Step 14:
    after trim these lines
  15. Step 15:
    finally trim these lines and confirm the command
  16. Step 16:
    draw a centerline. we will use it for mirror command
  17. Step 17:
    now we will use mirror command. use sketch--mirror commad. then select shown sections
  18. Step 18:
    click on this box
  19. Step 19:
    select the centerline
  20. Step 20:
    confirm that. now we will use trim command again
  21. Step 21:
    trim these lines
  22. Step 22:
    confirm that. then draw a centerline again. it will uses for mirror
  23. Step 23:
    open mirror command and select shown sections
  24. Step 24:
    click on shown box, select the mirror axis and confirm that
  25. Step 25:
    use trim command and make your sketch like shown
  26. Step 26:
    now we will use fillet command
  27. Step 27:
    enter shown radius parameter by 15mm, then only click on shown points
  28. Step 28:
    confirm that and your sketch should be like this
  29. Step 29:
    make same thing for the other points
  30. Step 30:
    sketch finished. please check it
  31. Step 31:
    now we will extrude this sketch. open extrude command
Please log in to add comments
