Tutorial: How to model Tire in PTC Creo Parametric and show design intent
Toroidal Bend feature with PTC Creo Parametric 2.0
Create Extrude feature - base shape
Add shape for your Tire (add or remove material)
Create Pattern feature from added shape (create tread design)
Add some Rounds/Drafts (customize tread design)
Create / Select Toroidal Bend feature
Select References tab >> Solid Geometry / Define... and select Sketch plane >> confirm Sketch
Create Profile section with Coordinate system - Finish sketch = OK
Select 360 degrees Bend from drop down menu. Choose Front and Back surfaces - system automatically will connect selected surfaces / references
(system automatically will connect selected surfaces / references)
Finish Toroidal Bend feature (final geometry)
Step 11:
You can add another features - Revolve feature (Rounds, Cuts etc.)
Step 12:
You can add another features - Create 3D text on surface - see video tutorial here: http://communities.ptc.com/blogs/vpalffy/2011/04/23/3d-text--offeset-from-the-surface
Step 13:
Create final rendering :)
