Tutorial: How to use Creo Simulate Lite in PTC Creo and show design intent
Small
Here is the short tutorial for you
    Create your model (200 surfaces max.)
    Select Application >> Simulate
    System open the Process Guide window for you - click Next>> (button)
    In Process Guide window select assign (do you need to assign Material for your model)
    Then select Next>> (button)
  5. Step 5:
    Now do you need to set the constraints for model - select constraints In Process Guide window
    You can set Displacement constraint or ...
  6. Step 6:
    ... Planar constraint or ..
  7. Step 7:
    ... Pin constraint or ..
  8. Step 8:
    ... Ball constraint
    for continue select Next>> (button)
  9. Step 9:
    Now set Loads
    Note: in Creo Simulate Lite you can set Force Load - it is not possible set Moments
  10. Step 10:
    Click this link to RUN an analysis
  11. Step 11:
    System open the Diagnostic window for you. Select Next>> (button)
  12. Step 12:
    View results of the analysis - click results link
  13. Step 13:
    System open the Creo Simulate Results window for you (you can save this analysis, print, etc.)
Please log in to add comments
