Tutorial: How to use "bend part" feature in Autodesk Inventor?
Small
Tutorial to use "bend part" feature in Autodesk Inventor.
    Model a part and invoke a sketch on the surface about which you will bend it.
    Create a line about which bending will initiate. Exit the sketch
    Click on the arrow mark shown in the picture just below the "modify" tool bar.
    Select bend part.
  5. Step 5:
    Select the bend line and other parameters.
  6. Step 6:
    Bend right will give the following result.
  7. Step 7:
    bend both will give the following result.
  8. Step 8:
    Flipping bend direction give result as shown.
  9. Step 9:
    You can change the bend type here.
  10. Step 10:
    Similar to above with bend radius increased. Click ok when finished.
Please log in to add comments
